Starter motor brush plate and brushes
redmidget
Post by redmidget »
I replaced the starter motor brush plate and pillar with brush for my 750 Paso with identical and available Kawasaki parts.
Kawasaki ZX750 (1996-2003) and ZX900 (1994-1997) use the same parts. Two parts numbers are required:
Brush plate with one brush attached: 14079-2055
Pillar with one brush attached: 21169-1058
Re: Starter motor brush plate and brushes
Post by Tamburinifan »
Good tip, thx f sharing! :)
ducapaso
Post by ducapaso »
Good tip, anyhow brushes are still available in duc dealers :thumbup:
I needed new brushes for my 900ss (1997) and baulked at paying nz$80 for the parts so I went to the local auto sparky and got a pack of 4 brushes for 12 bucks . Each brush needed a swipe with a file to fit and a small soldering job to fit to the brush plate. Most auto sparkies can also supply a suitable regulator / rectifyer at a good price . I hate to state the bleedin obvious but it is important to make sure that the starter motor is waterproofed upon re assembly
DonaldoDuck
Post by DonaldoDuck »
This is great info! Thanks!
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
Debonair
Post by Debonair »
Great tip, let's keep them coming! We all know that the parts for our Paso's are becoming more and more rare.
Rodney
Post by Rodney »
i replaced my starter motor from a 96 ss the starter motor i believe is the same even up to the ST2 and ST4 models.
persempre907
Post by persempre907 »
i'd put that in the FAQ.
Rodney
Post by Rodney »
Hi all.
just checked my ST2 2002 and starter motor has same part no.128000-6050
ducatipete
Post by ducatipete »
Is the round graphite bush that supports the armature available too???
Rodney
Post by Rodney »
you would have to check with your local dealer but if the brush plate is available you would assume the bush would be too.
ducatipete
already checked, brushes are not available here in the UK..I have replaced the starter with a 748 one, same part number, just would like to repair the old one as a spare....
Rodney
Post by Rodney »
look up "GOWANLOCH" they are in Sydney Australia. They have a lot of little odds and sods , they may have one.
Mustang505
Post by Mustang505 »
just to add to this list of info for starter brushes
I have just bought Honda parts that fit - turns out the starter motor used on the Paso & Sport is a Japanese one so parts fairly common.
Honda part numbers for the brushes are:
31201-HA0-004
31231-ZA1-003
I paid $NZ63.00 for both.
Clive
12 bucks
