907ie Exhaust - anyone de-cored one ?
englishstiv
Post by englishstiv »
I received the new nearside (right) silencer today for my 907ie which means I have a brand spanking new pair to fit and an old pair to play with so my question is has anyone de-cored their standard Paso silencers (mufflers).
Can it be done.
Obviously I know I will need to get it checked regarding the chip and the fuel mixture etc.
Any ideas - have you done it?
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Finnpaso
year: 0
Re: 907ie Exhaust - anyone de-cored one ?
Post by Finnpaso »
Sorry my bad english, but did U mean "recoating" of them ??? If so, then i am also very intrested, cause i have one set of 907 "black chromed" OEMs what need some work to look better.... :thumbup:
907IE -91 red/metal grey
907IE -91 red
de-core means removing or modifying the internals, like probably this guy did:
(this bike is currently on ebay)
englishstiv
Yes I did mean to take out the baffles.
DUCATI 907ie 1992
Finnpaso
year: 0
Post by Finnpaso »
ok, thanks! :thumbup:
907IE -91 red
Post by Tamburinifan »
I opened mine up so they have a 25mm hole straight through.
Have some bad cellphone pics of the operation if you want.
A bit better sound but not the real thing f a Duc.
A good welder could make the operation almost invisible, I`ve just used hitemp rattlecan paint:
englishstiv
My exhausts have the alloy outer cover that I may yet keep on, out of interest is the interenal baffle welded at front on the exhaust and did you cut it at weld seem on the large weld at the rear when you opened it up.
I sliced my Monster exhaust in half and debaffled it at the same time however I could not remove the internal baffle fully as it was still welded at both ends and I couldn't get to the front weld. It was niceand rorty and still quiet at slow speeds.
I did this. Once the rear cap was off I slipped the outer cover off and cut it at the other end which kept all the Ducati info/regs in situ. As the 907 outer cover is pinned to the internal sleeve I can only cut the baffles out.
http://i67.photobucket.com/albums/h293/ ... C00334.jpg[/IMG]
DUCATI 907ie 1992
Not 100% sure of what you mean.
I can mail my pics of you pm your mail adr.
