belts
dwarff
belts
Post by dwarff »
hi,before the inevitable happens im going to do the belts.can you help again please with locating a pair and how many teeth on the 906 belts? regards dwarff
JWilliam
Re: belts
Post by JWilliam »
You shouldn't need to count the teeth, the ducati part No. is 737.4002.1A, however I wil count them for you....70 and the teeth profile is round
Re: belts
the gates info is.............
PowerGrip HTD 5297-58070x18mm
Bucci aftermarket timing belts (each) 900 /ST2 2V 403-1061 $22.00 at
http://www.ca-cycleworks.com/shop/catal ... maint.html
and as stated standard OEM from Ducati 73740021A( superceeded to Ducati 73740031A) at your local Duke dealer
Re: belts
and they are the same for
907ie
900 Monster/IE (93-00)
900 Supersport/F.E/IE (91-00)
ST2 (97-00)
Cagiva 900 Elefant
Cagiva 900 Gran Canyon
and can be found at your local Duc dealer :-P
timmetje
Re: belts
Post by timmetje »
and more importent, its a easy job
persempre907
Re: belts
Post by persempre907 »
...taking a little care to the tension of the belts!
Finnpaso
year: 0
Re: belts
Post by Finnpaso »
5mm and 6mm allen wrenches for measuring right tightness! 5mm should go "easily" between smaler roller and belt, but 6mm should be "tighter"... :smoke: btw, little :wacko: after yeasterday eve, but now my ST2 have also new front steel braided lines(red surely)... I make all those from saparate components... Still som air in front system, but have to leave master to right position overninght, cause seems, that again air stays in upper banjo bolt.... like allways! I feed currently allways new liquid from down to up.... Better that way... :smoke: Ok, now have to put Sauna on and take some 1h walking trip to clear head little (after yestaerday :beer: ) .....
907IE -91 red/metal grey
907IE -91 red
dwarff
Re: belts
Post by dwarff »
thanks evryone,this is a brilliant site,if you ever want to know anything about smoking and drinking im your man.there was some belts on ebay going cheap and the seller stated the number of teeth,ive snapped the clipon off trying to straighten it.regards dwarff
Re: belts
I hope they are not NOS( new OLD Stock) :,(
Re: belts
is there a production date printed on the belts usually ? (the belts of my Gilera had that, the last times on my Duc I had them changed so I don`t know :)
Re: belts
After doing a little research it seems the gates belt has changed numbers at least here in the US. I am currently waiting on a response from Gates on the new upgraded belt number and I will forward it along asap.
The response :evil:
Thanks for your inquiry however that belt is not something we offer here
in the states, unfortunately it's probably back to Ducati.
Seems it is a German made belt,Perhaps one of you from Germany can verify the new number? :?:
Finnpaso
year: 0
Re: belts
Post by Finnpaso »
dwarff wrote:thanks evryone,this is a brilliant site,if you ever want to know anything about smoking and drinking im your man.
Dont You want to know ANY VERY GOOD advices about WOMEN at all ??????? If you want, let us know.... :smoke: :beer: :smoke: :beer: :smoke: :beer: :smoke: :beer: :smoke:
907IE -91 red
