That happened to me a few years ago, if its the blind hole thats stripped then if I remember correctly it is possible to tap a thread into unused alloy at the bottom of the hole and use a longer bolt.The best fix however would be to put a thread insert in (look up"Helicoil" http://www.helicoil.in/ )this will be better than new(I was told that they were developed to stop the wings falling of Spitfires !!) and is the only real way to fix the top bolt thread if its that one thats gone,they are available as kits for DIY installation or any engineering firm can do it for you.bender wrote:when i was tightening the chain one of the for bolts on the back of the swig arm striped. any ideas on how to fix the problem???? thanks bender....![]()
