750 paso swing arms
bender
750 paso swing arms
Post by bender »
when i was tightening the chain one of the for bolts on the back of the swig arm striped. any ideas on how to fix the problem???? thanks bender.... :,( :,( :,(
pasotibbs
Re: 750 paso swing arms
Post by pasotibbs »
bender wrote:when i was tightening the chain one of the for bolts on the back of the swig arm striped. any ideas on how to fix the problem???? thanks bender.... :,( :,( :,(
That happened to me a few years ago, if its the blind hole thats stripped then if I remember correctly it is possible to tap a thread into unused alloy at the bottom of the hole and use a longer bolt.The best fix however would be to put a thread insert in (look up"Helicoil" http://www.helicoil.in/ )this will be better than new(I was told that they were developed to stop the wings falling of Spitfires !!) and is the only real way to fix the top bolt thread if its that one thats gone,they are available as kits for DIY installation or any engineering firm can do it for you.
bender
Post by bender »
thanks it is the bottom hole so i will try the "Helicoil" i will let you know how it works. thanks again bender :beer: :beer:
nilaus
Post by nilaus »
I added 3 helicoil in my swing arm last month and when i was at it, I inserted in front fork for the callipers. They where getting to a state, that I was nervous when tightening them. Alloy and steel bolt’s?? there should be a law stating, that you had to insert an helicoil in to a alloy thread :) :beer:
bender
Post by bender »
sounds like it worked good for you hope that it will work good for me to thanks for you're help with this problem. i will let all of you know thanks bender :evil: :evil:
jinshiyang
Post by jinshiyang »
thanks it is the bottom hole so i will try the "Helicoil" i will let you know how it works. thread insert helicoil
