This is a little different question when compared to the usual "What tires will fit".
I would like to understand what exactly the numbers mean.
For Example 150/80 VB 16 (71V)
First off, I get the 150 width, 80 sidewall profile, V Rating and 16" rim, What I don't quite understand is the 71V. Can anyone shed some light on this often forgotten tire specification number?
Chris
Tire Size Question
Tire Size Question
1978 Yamaha 650 Special
1987 Yamaha FZ600
1993 Suzuki GSX-R 1100
1995 Kawasaki Ninja 250R (wife's)
1988 Ducati Paso 750
2009 Yamaha FZ1
1987 Yamaha FZ600
2009 Yamaha FZ1
Re: Tire Size Question
normally it should be 150/80B16 71V.
80 is the height of the tire as percentage of its width.
A 150/80 should be 150mm wide and hence 120mm high.
71 is the weight index. 71 corresponds to 345kg max. load (with proper set tire pressure). Lower tire pressure will reduce max load. At speeds above speed index of the tire max load will decrease.
B stands for bias belted, R would mean radial.
Thanks for the info
1987 Yamaha FZ600
2009 Yamaha FZ1
1987 Yamaha FZ600
2009 Yamaha FZ1
