So that was the story from 1998 to end of 2009.
Beginning of this year I decided I didn`t like to lose the most of the most of the range/possibility to adjust the chain tension and swapped to a new 907ie swingarm I`d gotten years back when thinking about the wheel conversion. Clearances wouldn`t be any issue (except to tire chain) and I could play with the bikes geometry by having the possibility to move the wheel back, extending the wheel base and lowering steering angle a bit by the same time.
For keeping 16" wheels this is the option that requires the most parts fabricated incl. wheel and bearing spacers due to the different size axle. (having all the parts except wheels I now could do a 17" wheel conversion in less than one hour if I ever wanted to)
Also the rear brake caliper bracket won`t fit anymore and the one of a 907ie wouldn`t go with the 16" rim as it`s made for a 245mm brake disc which you can`t mount on the Oscam rim. Therefore the rear brake had to be modified, too which I had intention to do anyway. Luckily a friend helped me out doing some calculations for the front mounting bracket I had designed and choosing the right material.
During the engine rebuild all engine bolts were replaced with new ones and I had continued that when rebuilding the frame the last time. All small bolts & nuts were replaced with stainless steel parts, the ones for brake and fork with new zinc plated steel bolts. As a consequence when all parts for the new wheel/swingarm combination were machined and send to anodizing I had all the original/special bolts of frame and swingarm zinc plated & yellow alodined, too.
Looking scary big
If someone is wondering those are the bolts for 2 complete swingarms and not all those spacers on the left were for this project
M10 to M8 adapter bolt & modified brake caliper plate
In case you`re wondering using parts from a Superlight won`t work no matter if you have a P750 or a 907ie. The Superlight has a shorter swingarm and no lower frame tube from one side to the other. Hence the front mounting adapter is too short and the connecting rod also.
The trolley or whatever it`s called I got meanwhile is a blessing for a narrow garage (it requires an even flloor though because of its small wheels). I wouldn`t have made it though to put it under the centerstand myself. I had to use a rear bike stand to lift the bike, then position the trolley and let the bike down. To get the bike off it is easy, to get it on it is hard.
Offsetting the chain.
