Shim kit info
Shim kit info
Hi, I need to do a valve adjustment what (mm) kit do I need?? Also what company do you guys think has the best deal???????
- jcslocum
Re: Shim kit info
You need a kit for the early 2-valve engines.
Check out these rental tools:
http://www.ducatitoolrental.com/index-6.html
Re: Shim kit info
Have a look here:
http://www.emsduc.com/products.html
and here:
http://www.emsduc.com/assets/ducati_shim_chart.pdf
and here:
- Skins
Re: Shim kit info
Make sure your motor is absolutely cold, in other words it has not been run that day, when you measure your clearances, otherwise your measurements will not be correct. If you need more clearance, you can simply remove metal from the tappet by stoning.
- ducapaso
Re: Shim kit info
Hope NOT from the hardened side!!!Skins wrote: If you need more clearance, you can simply remove metal from the tappet by stoning.
ex...Red "smooth" 753349
Re: Shim kit info
Thanks guys
