Shim kit info
Vince
Shim kit info
Post by Vince »
Hi, I need to do a valve adjustment what (mm) kit do I need?? Also what company do you guys think has the best deal??????? :?
jcslocum
Re: Shim kit info
Post by jcslocum »
You need a kit for the early 2-valve engines.
Check out these rental tools:
http://www.ducatitoolrental.com/index-6.html
Duc906
Re: Shim kit info
Post by Duc906 »
Skins
Re: Shim kit info
Post by Skins »
Make sure your motor is absolutely cold, in other words it has not been run that day, when you measure your clearances, otherwise your measurements will not be correct. If you need more clearance, you can simply remove metal from the tappet by stoning.
ducapaso
Re: Shim kit info
Post by ducapaso »
Skins wrote: If you need more clearance, you can simply remove metal from the tappet by stoning.
Hope NOT from the hardened side!!!
Vince
Re: Shim kit info
Post by Vince »
Thanks guys :beer:
