Note the engine is mounted in the frame without the front engine mounts.Pics of the strengthed motor mounts would be nice.
Rebuilding my 907 ST3
Re: Rebuilding my 907 ST3
- JoKing
Yes, the upper forward mount on the right side is still at the paintshop...
The lower won`t be used.
I think i do not need it. But i am not sure. I will test it.
The ST3 engine offers no possibility to use it.
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
- JoKing
Today i flooded the frametubes where possible with fluid film, to prevent oxydation damage.
86` Ducati 750 Paso
86` Ducati 750 Paso
- 907pasonut
looking at this picture you're about 3 to 4cm too high on the front sprocket, you may not be able to lower the engine,
but you could have a smaller sprocket setup to re-direct the chain away from swingarm,
I'm sure you could borrow a chain guide from some dirt bike...it should be doable
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
- JoKing
Sprocket& swingarm-axis are exactly on the same hight.
How does it look like in original?
86` Ducati 750 Paso
86` Ducati 750 Paso
- Ducolaf
See a special tool, a green toothbrush. Recognizable, and also in my toolbox present. . . .
Proud owner of a;
- Ducati 907 ie 1992 in red
Proud owner of a;
- JoKing
Ducolaf wrote:See a special tool, a green toothbrush. Recognizable, and also in my toolbox present. . . .
The MOST important tool. Next to my fingers...
86` Ducati 750 Paso
86` Ducati 750 Paso
- Finnpaso
- year: 0
JoKing, Looking that toothbrush: Too dirty teeths !!! Use more toothpast ! Do You have to kiss Your wife still ?
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- JoKing
86` Ducati 750 Paso
86` Ducati 750 Paso
- Bock900r
Have a lookJoKing wrote:Sprocket& swingarm-axis are exactly on the same hight.
- Frame.JPG (100.22 KiB) Viewed 8845 times
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
- 907pasonut
after looking at both pics, the front sprocket looks to be in the same spot, (my apologies for barking up the wrong tree) it just didnt look right, I should of taken the cover off and had a proper look...then the swingarm chain damage was most likely caused by a loose chain, had a look at my swingarm and it also has a little chain groove, but very small, a chain guide or nylon pad might not be a bad idea to prevent this and check chain tension more often
Cheers Claude.
- JoKing
How is the mileage of your bike?
Mine has altogether about 145.000km on the odo...
86` Ducati 750 Paso
86` Ducati 750 Paso
- 907pasonut
not many, 17,623km
Cheers Claude.
- JoKing
I think you will have the same damage, when your bike reaches the 146tkm...
86` Ducati 750 Paso
86` Ducati 750 Paso
- 907pasonut
you could be right...when I get some time I'll remove the sprocket cover and inspect if there is any damage near swingarm bearing, I still think this is not a design fault, but a maintenance issue
Cheers Claude.
