How to Set the TPS for the 907
- Fast Eddie
- year: 1993
Can anyone tell me what the factory settings are for the 907 using a digital volt meter? I'm going to try to see if the TPS is off and if that's why it dies when you nail the throttle or try to go over 5500 rpm.
Ed
'93 Ducati 907ie, '01 Ducati ST4, '07 Honda ST1300A
Re: How to Set the TPS for the 907
http://home.kpn.nl/duran103/pics/p7-p8.pdf
Basic setting is really only:
Wind out idle & throttle stop screws til they don`t affect tps.
Remove cover of big AMP connection into ECU.
Measure + & - mV at pin 11 &17. When correct: 150 mV +/- 2mV.
Recommended Idle mV I haven`t seen but around 270-350 mV seems plausible.
Just set mine, idles at 300.
but a dvom may not be the BEST tool
The best tool is ......?
analog
- Fast Eddie
- year: 1993
Tamburinifan wrote:http://home.kpn.nl/duran103/pics/p7-p8.pdf
Gert,
Thanks for the info. That should be very helpful. I'll get this bike running right yet!
Ed
