Garage Stand for 907ie
ltbauzo
Hi All,
So my 907ie sits in the garage for a few months at a time as I do not get it to ride it too often anymore. I just got new tyre and noticed that, for those long months when the bike is still on the central stand, the front tyre has all some of the weight of the bike on it. The tyre becomes oval and does not ride as well...
Does anyone have any recommendation for a central stand to use in a garage for my 907ie? Or any other suggestions?
Thank you,
ltbauzo.
Thank you,
ltbauzo.
Re: Garage Stand for 907ie
Why not just move front wheel a bit like once a month or so?
F sure cheapest...
F sure cheapest...
ltbauzo
Hey Gert..good idea but I live 1500 Km from my beloved duke
You should be able to put something together out of 2x4 fairly cheaply.
I have as yet not put a centerstand on my 906,have one just to lazy to do it.
So I cobbled this together one day a while back. I'm sure it could easily be made to lift
the front wheel off the ground as well,just to give you an idea
while the bike is on the centre-stand put a bag of cement on the back of the seat..
this will take the load off the front.
you could also tell your wife that you're taking her for a ride and to wait for you on the pillion seat...
ask her if she enjoyed the ride when you get home.
Laddie
CB750K7
CB500Four
CB250
CB175
DT175 Yam
PE250 Suzuki
CB750K7
CB500Four
CB250
CB175
DT175 Yam
PE250 Suzuki
Duc750
- year: 1993
I sit mine on paddock stands at both ends - the best I have used are the Harris ones as they stainless steel and very stable
- Bock900r
Looks a little like Redneck Engineeringhiggy wrote:You should be able to put something together out of 2x4 fairly cheaply.
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
pipe jobby is good, wtf u Thinkin on the second one ? Hows that one going to help
- ducbertus
put the bike on the centerstand. shove a 1 or 2 cm. thick piece of wood underneath the centerstand by tilting the bike over forward and backward.
now you have enough air under the rear wheel for the next step.
take the front wheel from the ground and place a wooden rod like a piece of broom stick between the front cylinder and floor.
now both the wheels are free.
Bertus
Bertus
Yeah,that could do and simple to boot
- JoKing
Try lifting the bike by hanging it on the upper fork clamps & the passenger holding thing....
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
