907 parting out.
Re: 907 parting out.
I don't have a chip available but should have the mapping as a file. If you can find someone that can burn eproms, I can mail you the file so you have an eprom made.
A few years ago the eproms were still available from Ducati. Can't imagine it is a fast moving part, so perhaps your lucky there. Price was quite decent.
If you still have no ECU let me know, a friend of mine in the UK (from the Cagiva Elefant brotherhood) that fiddles a lot with these bikes might have 1 or 2 available.
Michiel
Michiel
duc24u
well I got a computer and new coils but I still have no spark any ideas
nickta
Hi Duc24uduc24u wrote:well I got a computer and new coils but I still have no spark any ideas
I don't suppose you have checked the outputs from the magnetic pickups for TDC and RPM? I just pulled the plug on both these, and there is more chance of a Christmas card from the ex spouse than the 907 starting if these are U/S. I don't have the Multimeter here at the moment, so can't tell you what sort of resistance or voltage these should give out. They should be a coil (magnet on the flywheel I'm guessing?), so when the magnet passes, it gives a voltage, probably in the order of mV's. As a guess, coil resistance would be around 30 ohm. Pull the plug on the ECU and measure resistance between pins 3 and 4 (back into the wiring loom) and you should see the RPM sensor and pins 5 and 23 for the TDC sensor. Disconnect the battery as a precaution too (I'm a bit of a chicken when playing with Micro's!).
Nick.
Nick beat me to it, I also think it's one of these sensors that is gone.
Datasheet can be found here:
http://endless-horizons.net/efi/rpm.htm
- Ducolaf
Recently saw some modified chips for a 907 with open mufflers on USA Ebay, for a too high prize for me. Perhaps you could find it there, were the last 10 or 12 pcs from that modification company. In house programmed. . . . . .
Proud owner of a;
- Ducati 907 ie 1992 in red
Proud owner of a;
duc24u
I pulled the connector from the coil and had good power through the initial turn on and when hitting the start button, So if power is there and the coils are new, you think it is another problem that would not allow spark to happen? I will check into this, but that is kind of odd. Thanks for the info I will look deeper.
- ducbertus
Hi Duc24u,
actually when the 12V power to the coil is interupted by the ignition module you get a spark on your plug (break down of the magnetic field). you mentioned power on the plug, but when you turn the engine slowly by hand does the power drop off? with the engine running the power break down is only for a few milliseconds and hardly visible by the naked eye.
if the power does not drop of, the coils are not suspected, but the components "upstream" are.
Swapping parts with known functional ones is an option to isolate the defect.
you need a friendly donor, that's all.
Bertus
Bertus
nickta
Hi duc24a.duc24u wrote:I pulled the connector from the coil and had good power through the initial turn on and when hitting the start button, So if power is there and the coils are new, you think it is another problem that would not allow spark to happen? I will check into this, but that is kind of odd. Thanks for the info I will look deeper.
Which side of the Coil are you getting 12V. The Primary or the Secondary?
If you want to check the TDC and RPM pickups, they are cable tied to the frame behind the LHS side cover. On my 907, 1 connector is a white 2 pin, the other is a black 2 pin. Pull these plugs apart and you should see some resistance on a Multimeter looking into the pickup.
Just had a thought. Has any work been done on these pickups in the past. If you are not the original owner, maybe by a previous? I can't remember off the top of my head, but they probably have the same connector on the sensor side of things. They may have been crossed over at some stage? (Black to White etc). I doubt the bike would start if they were crossed. You never know your luck?
Cheers.
Nick.
duc24u
You guy's are amazing that was it they were swapped, She fired up and I have never heard a sweeter sound...:O
- Ducolaf
There is a P8 computer being offered in the Netherlands, price 200 Euro. Sounds not too unacceptable.
I regularly visit this company for parts on older Ducati's. Also more Paso or 906 /907 parts available.
See the P8 here: http://link.marktplaats.nl/596889807
See the list of other items here: http://verkopers.marktplaats.nl/15786089
Good luck!
Olaf
Good luck!
Olaf
Proud owner of a;
Proud owner of a;
- albert.marr
hi, do you still have bits and pieces of your 907 still available?duc24u wrote:Well unfortunately I have to part the bike out the computer is shot and I cannot get another. If anyone needs parts from the 92 907ie let me know.
- englishstiv
Hopefully not as he got the beast running again? If the thread list reads right?hi, do you still have bits and pieces of your 907 still available?
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
There are several owners here can set you up with all you need
