stock rear shock
stock rear shock
Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
- Finnpaso
- year: 0
If U have Öhlins, ITS that, but i dont know that older Marzhocci in 750. Btw, that Öhlins is much better shock
That 907 later model rear Marzhocci is, cause mine was rebuild by Öhlins maintainer. Also i find rebuild kit from Ducati, but i am not sure, is it anymore available.
Finnpaso
Paso 750
Paso 907IE
Finnpaso
Paso 750
Paso 907IE
rear shock
My Paso has the stock Marzocchi shock. I'd like to get a used Ohlins for it. What part/model number Ohlins will fit a 750 Paso? I'm also going to call the dealer Monday and find out if there is a rebuild kit for the Marzocchi.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
Re: stock rear shock
at the moment in ihbähbavarian wrote:Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
http://cgi.ebay.de/Ducati-PASO-906-Marz ... dZViewItem
or
http://cgi.ebay.de/Ducati-PASO-907-i-E- ... dZViewItem
rear shock
Thanks for the link ved, but that shock and rebuild kit won't work on a 750's shock. The rebuild kit won't fit the shock and the shock is too large for the limited space on the 750 Paso from what I have read.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
I have the same seeping issue with my 88 Paso shock. Works Performance produces a shock for the Paso. The remote reservoir installs with hose clamps, so it's not the cleanest install. My shock continues to work pretty well despite a drip here/there, so I haven't installed the WP unit yet. I plan to weld up an aluminum clamp of some sort, that will make the shock worthy of being installed on my Paso. Hose clamps!
rear shock
The Works Performance shock is only $350 as well. If you do get one let me know how it feels. I've also had a few crazy thoughts of just getting an Ohlins, but have been so far unable to find any info as to which model would fit the Paso.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
