stock rear shock
bavarian
stock rear shock
Post by bavarian »
Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
Finnpaso
year: 0
Post by Finnpaso »
If U have Öhlins, ITS that, but i dont know that older Marzhocci in 750. Btw, that Öhlins is much better shock :thumbup:
That 907 later model rear Marzhocci is, cause mine was rebuild by Öhlins maintainer. Also i find rebuild kit from Ducati, but i am not sure, is it anymore available.
Finnpaso
Paso 750
Paso 907IE
bavarian
rear shock
Post by bavarian »
My Paso has the stock Marzocchi shock. I'd like to get a used Ohlins for it. What part/model number Ohlins will fit a 750 Paso? I'm also going to call the dealer Monday and find out if there is a rebuild kit for the Marzocchi.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
ved
Re: stock rear shock
Post by ved »
bavarian wrote:Is the stock rear shock on a '88 750 Paso rebuildable? Mine is starting to seep oil.
at the moment in ihbäh
http://cgi.ebay.de/Ducati-PASO-906-Marz ... dZViewItem
or
http://cgi.ebay.de/Ducati-PASO-907-i-E- ... dZViewItem
bavarian
rear shock
Post by bavarian »
Thanks for the link ved, but that shock and rebuild kit won't work on a 750's shock. The rebuild kit won't fit the shock and the shock is too large for the limited space on the 750 Paso from what I have read.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
davidhughrose
Post by davidhughrose »
I have the same seeping issue with my 88 Paso shock. Works Performance produces a shock for the Paso. The remote reservoir installs with hose clamps, so it's not the cleanest install. My shock continues to work pretty well despite a drip here/there, so I haven't installed the WP unit yet. I plan to weld up an aluminum clamp of some sort, that will make the shock worthy of being installed on my Paso. Hose clamps!
bavarian
rear shock
Post by bavarian »
The Works Performance shock is only $350 as well. If you do get one let me know how it feels. I've also had a few crazy thoughts of just getting an Ohlins, but have been so far unable to find any info as to which model would fit the Paso.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
Finnpaso
year: 0
Post by Finnpaso »
Hi !
Original Paso 750 Öhlins is modell: CA 508, but i am 98% sure, that You cant find such new from any Öhlins shop anymore.
Finnpaso
Paso 750 -89
Paso 907IE -91
ST4S -02 (tomorrow i got it from Germany) :lick: (cant wait!!!!)
