300 to 320mm adapters?
Post by Tamburinifan »
Someone selling any adapters f using 320mm discs on the 907?
ducinthebay
Re: 300 to 320mm adapters?
Post by ducinthebay »
Don't think I've ever seen those.
angelix
Post by angelix »
nope already checked...
I ended having a set custom made by DISCACCIATI - Italy (full floating cast iron).
ducinthebay
The other way is to get some 1993 907 fork legs that came with the 320 mm rotors. Did the 1989(1990?) 851 have 320 rotors? They had M1R forks, and 17" wheels for one year.
persempre907
Post by persempre907 »
ducinthebay wrote:The other way is to get some 1993 907 fork legs that came with the 320 mm rotors. Did the 1989(1990?) 851 have 320 rotors? They had M1R forks, and 17" wheels for one year.
The 851 with 17" rims had 320 mm rotors.
ducbertus
Post by ducbertus »
but the total lenght of the 851/M1R is shorter as in the 907.
Bertus
ducinthebay
Yes, the 851 forks are shorter, and shorter travel. But if you get just the lower fork legs, they will fit on your existing forks.
Phil
