Dashboard Died
sltillim
Dashboard Died
Post by sltillim »
Hi all,
I Was riding today after the bike had a year long hibernation and the dash died on me. Obviously the mechanical MPH and RPM still work. I can start the bike just fine. No gas level, water temp, turn signals, clock (which is still good) or information lights (kickstand, neutral, etc.). Just want to check if this has happened to anybody else or is a common issue. I did a search the forum but didn't find anything. I looked at the work shop manual and didn't find anything.
a couple questions:
Is this a single fuse that does the dashboard and turn signals?
If so, which one(s) fuse runs the dash (F2-F5?)
Are any of the connections known to fail?
I will start checking all the connections in the morning. I did find in my search that there are three connectors that go to front of the bike - any confirmation here would be very helpful...
I have to do a major in the next couple months on my own for the first time - doesn't look too complicated as I am used to picky, complex Italian machines.
Any direction is certainly appreciated!
Re: Dashboard Died
With all them things crapping out at once Id be looking at the earth wire/connection for the dash ( something that is common to all failed things ) usually bolted to the frame either side of the steering head
Derek
Re: Dashboard Died
Post by Derek »
The only thing I can see that will fit all these symptoms is the 4 pin connector has popped out of the back of the dash.
Re: Dashboard Died
most likely,could still be a ground :thumbup: :beer: :beer:
sltillim
Re: Dashboard Died
Post by sltillim »
You guys are funny. I will report back to let you know who wins!!!
Derek
Re: Dashboard Died
Post by Derek »
Nah! If it was simply a ground the neutral light, oil light, side stand light and generator warning light would all still work. :D
Re: Dashboard Died
Duc750
Re: Dashboard Died
Post by Duc750 »
there's another option - if the top mount for the dash fails the dash flops back and can break the PCB track where it rubs against whats left of the mount.
Ducolaf
Re: Dashboard Died
Post by Ducolaf »
Well, the winner on problem finding is!?
Proud owner of a;
- Ducati 907 ie 1992 in red
sltillim
Re: Dashboard Died
Post by sltillim »
Ducolaf wrote:Well, the winner on problem finding is!?
If all fails start at the beginning- one 15a fuse!!!! All fixed.
Re: Dashboard Died
if it was a blown one, why did it? ;)
Thebenelliman
Re: Dashboard Died
Post by Thebenelliman »
If the battery is not fully charged this causes the voltage to drop which in turn increases the current ( amps) and this can blow the fuse! Always have a good battery on a bike as low or unstable voltage can damage electronics ie the ignition or fuel injection system !
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
1980 Benelli 254
Derek
Re: Dashboard Died
Post by Derek »
Thebenelliman wrote:If the battery is not fully charged this causes the voltage to drop which in turn increases the current ( amps) and this can blow the fuse! Always have a good battery on a bike as low or unstable voltage can damage electronics ie the ignition or fuel injection system !
You obviously don't understand Ohms Law which says that I = V/R, the current is equal to the voltage divided by the resistance. The resistance of a circuit remains constant, so if the voltage is reduced, so is the current.
I don't know where the notion that the current varies inversely to the voltage comes from Image
Thebenelliman
Re: Dashboard Died
Hi Derek you are correct my mistake! But electronics are still effected by increased or decreased voltage!
The Benelliman
1992 907ie
1981 Benelli 250 2c
1980 Benelli 254
Re: Dashboard Died
Excuse me Derek, not everything is ohmic and under the correct conditions non ohmic devices can include the battery
