can somebody measure that?
diameter of thermostat hose connections?
- Derek
- year: 1994
Re: diameter of thermostat hose connections?
The straight and side ports are 26.5mm. The right angled port is 24.0mm. Each of them has a 1mm lip around the outer rim.
Thank you Derek
I`d seen a thermostat that looked like the one of the 907ie but it`s for cars and so the connections are too large.
- photo.jpg (84.37 KiB) Viewed 5718 times
- Gates TH14580 80°.jpg (5.67 KiB) Viewed 5718 times
