diameter of thermostat hose connections?
can somebody measure that?
Derek
Re: diameter of thermostat hose connections?
Post by Derek »
The straight and side ports are 26.5mm. The right angled port is 24.0mm. Each of them has a 1mm lip around the outer rim.
Thank you Derek :thumbup:
I`d seen a thermostat that looked like the one of the 907ie but it`s for cars and so the connections are too large.
Gates TH14580 80°.jpg (5.67 KiB) Viewed 5719 times
