Ducati 907ie Rectifier
englishstiv
Post by englishstiv »
I have found a UK supplier of this which I believe is supplied by Electrosport in the states are they suitable replacements?
http://www.electrosport.com/media/catal ... r510_1.jpg
https://images-na.ssl-images-amazon.com ... L1000_.jpg
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
englishstiv
Re: Ducati 907ie Rectifier
ANY ONE KNOW - ARE THEY ANY GOOD/
DUCATI 907ie 1992
Finnpaso
year: 0
Post by Finnpaso »
Looks, that such is not Electrex. I dont know realibility of those, but Electrex is very good one. Stiv, if You want Electrex, i think, that they have importer from USA to UK .... As last time, when i ordered them from USA(3 units), items came to me from UK, not direct from USA! ....and then i had not to pay any taxes, VAT's etc...
Antti
907IE -91 red/metal grey
907IE -91 red
Finnpaso
year: 0
Post by Finnpaso »
Still one note: Take all such connectors away and WELD wires very well and insulate them with 2 layers of heat shrink! Most of those regulator/generator problems are caused by poor/resistive CONNECTORS ! I know, i am elecrician... :thumbup:
907IE -91 red
englishstiv
:thumbup: Antti
DUCATI 907ie 1992
Stiv, why are you looking for a regulator in the first place? You mentioned you already had more than one. Imho it makes no sense spending the money if you're not certain that's the main issue.
Finnpaso
year: 0
Post by Finnpaso »
If regulator is failed, it can broke also alternator in left side of engine and SAME VIA VERSA. Allways with such problems have to measure insulations of generator (with suitable insulation meter/tester, what gives 250 test voltage!)and also all wires with Ohm meter. Regulator CANT be measured 100% surely, no matter in some Haynes Ducati manuals are noted some ohms between regulatos wires. Also regulator plate(case) ground must be 100% to bike frame! Same with wires from regulator to battery! Most these "cases" are coming from poor connectors between regulator and generator in left side little under steering head bearing. Also ST-series bikes suffer from these POOR/DIRTY connectors in same wires.
907IE -91 red
Derek
Post by Derek »
paso750 wrote:Stiv, why are you looking for a regulator in the first place? You mentioned you already had more than one. Imho it makes no sense spending the money if you're not certain that's the main issue.
And if I remember correctly he bought my old one which worked perfectly well before I replaced it with a MOSFET Shindengen.
englishstiv
My problem is that I want to test a brand new perfect Regulator/rectifier for a base level test as everything else seems to pan out okay.
All three current units that I have are just frustrating the issue as they all give a varied and different perspective.
Neither are for certain giving me any charge rate.
I have cut away as much of the shrouding that I can on the loom and apart from some oily damp residue no sign of scorch or burn marks, none of the plug sockets are corroded or damaged, Fuses are perfect and new.
All the earths are clean.
The engine on/off switch is in perfect working order and the spare when fitted gave the same results.
I am going to try some new Relays and I have a used but good Power Module waiting to be collected at the Post Office (all the way from Hawaii !!)
It is being a pig of a job to suss out what is the gremlin lurkin underneath.
I am also considering trying to find a local company that might be able to confirm if the ECU is at fault somewhere.
Please appreciate guys I am on a limited budget spend with my bikes and don't have access to unlimited funds for top dollar bespoke gear on this bike or any of my bikes for that fact. :thumbup:
DUCATI 907ie 1992
englishstiv
Derek last time I rode the bike she had your rectifier fitted and the man from the RAC suggested that might be the problem although he was not in any way familiar with the 907ie model. Problem is one of the other issues I had may of knackered yours in the process of the 30 mile ride I had before the battery died. I have a new rectifier but that caused the on/off switch problem that I still have, I admit it was a cheap one under £50.00 but I was hoping it might assist in confirming any other problems not creating a whole new issue. :,(
Hence my question.
DUCATI 907ie 1992
englishstiv
Antii I have a good second hand Power Module ( all the way from Hawaii) awaiting my collection.
I have done due diligence on all the relevant earth and connectors and checked under the shrouding of the loom and all the connectors.
Alternator tested all within parameters
Antii
minulla ole hyvä toinen käsi tehomoduuli (aina Hawaii) odottaa minun keräämistä. Olen tehnyt due diligence asianomaisen maan ja liittimet ja valvotaan burkaan ja kaikki liittimet. Laturi testattu kaikki parametrit
DUCATI 907ie 1992
Finnpaso
year: 0
Post by Finnpaso »
Stiv, I have also one spare power module in my shelves, but never needeed it yet. It was from some car what use same module and exact same numbers on it. I have also some spare 907ie ECU's if You need such. But never use any multimeter to test MOSFET Regulator! MOSFET is such component (inside unit), that need to "ground yourself" as it needs only small voltage peak and such is dead then. There can be MOSFET regulators, but i havent seen such in Ducati spare part markets. Those originals are "crap" and Electrex is best.
Antti
907IE -91 red
Finnpaso
year: 0
Post by Finnpaso »
Btw, You are "lucky" if generator is ok, as if it fails, then it cost doubble (to rectifier) and have to open left side of engine... :thumbup:
Antti
907IE -91 red
Derek
Post by Derek »
Finnpaso wrote:... i havent seen such in Ducati spare part markets...i
Most of the current generation of Ducatis are now fitted with Shindengen MOSFET regulators.
Finnpaso
year: 0
Post by Finnpaso »
Thank's Derek! I know, that many Duck's use Shindengen jap regulators, but i didnt know that they use MOSFET's inside them. .....have to use more "google search" :mrgreen: :thumbup:
907IE -91 red
