Mirrors
motiztab
Mirrors
Post by motiztab »
Are the mirrors adjustable? The mirrors in mine are fixed are all the same?
redpaso
Post by redpaso »
The Mirrors are not adjustable. Don't think it would help improve the rear view much anyway. But when you have a lovely lady on the back why would you want to? :D
Redpaso
motiztab
Post by motiztab »
She never goes on the back, she's always on her bike.
I just wondered, from the other postings it would seam that a non Ducati ones come on the market.
DesmoDog
Post by DesmoDog »
Don't know about the 750, but the mirrors on my 907 do have some adjustability in them... the plastice the glass is mounted on is on a pivot. It's hard to move, but they will move
-Craig
fasterdammit
Post by fasterdammit »
Yes, I've had one of those pods apart and the mirrors are adjustable. Not easily, and it's not a great design (for more reasons than just adjustability) but they do pivot around in there.
1988 Paso 750 #753965
1997 Monster 750
Finnpaso
year: 0
Post by Finnpaso »
ALL original mirrors are adjustable !!! But if havent move them for many years, they get stucked. I have fixed them many times, so i know.... Crashed my Pasos 3 times :mad: :sad: :mad: :sad: :mad: :sad:
907IE -91 red/metal grey
907IE -91 red
motiztab
Post by motiztab »
Now you have got me thinking, as mine do not move if I can get them off can I free them up with a good soaking of freeing agent. So how do they come off, do I have to take the nose cone off? or can I get to some bolts by removing the front side panels?
redpaso
Post by redpaso »
So the Paso mirrors actually ARE adjustable????????????? :confused:
Well bugger me! :eek: I have looked long & hard at mine & summised that they were just glued straight to the pod itself. I have even prodded & poked at them just to make sure. My old K100RS had the similiar Pod set up with indicators & mirrors in the one unit but they were easily moveable & there was room about the recessed mirror.
I have not removed the pods to check from behind but there does not seem to be any room about the recessed Paso mirror for it to move. I had better try again & carefully (& nervously)push a bit harder.
It is not actually going to make much difference though is it?
:D
Redpaso
motiztab
Post by motiztab »
I agree but if things are ment to work I like them to!
Finnpaso
year: 0
Post by Finnpaso »
As I told, all MY 750 Paso:s and 907IE:s ORIGILAL mirrors are adjustable! I am 110% sure about it. Remembering, that U have to take blinker lens and bulb holder, etc. first away, then You can see some screw there(what is very often rusted) and hold another hand in mirror side and turn that screw open. If U managed that, then U can take mirror away and then You see that adjusting system: There is metal/plastic ball joint, what is just that adjusting. Normally that ball joint is stucked, if havent move it for long time. But DONT take that ball joint open, cause that plastic have hardened, so that plastic gets broken very easily, what happened to me one time and i had to glue that ball joint ..... Better sparay some thin lubrication inside that ball joint and start to move mirror little by little..... Was this enough badly explained??? :thumbup:
907IE -91 red
motiztab
Post by motiztab »
Finnpaso
In answer to your question the answer is yes!!
But I do understand.
Just had to rush out and have a look! I see that the ball joint is part of the mirror glass mounting. Got it soaking now.
Marinus
Post by Marinus »
Now you will be able to see your knees properly :D
Rodney
Post by Rodney »
:D the mirrors are only good for looking at your knees or the gutter if you can manage to see them around the handlebars.
mine move freely without being sloppy, but are useless.
RODNEY
fasterdammit
A friend of mine mounted a pair of those car 'blind-spot' mirrors on his bike (not a Paso). They're convex, so they offer a slightly distorted view - but of a whole lot more real estate. If you can get used to them, they'll let you see more than your knees. I have them on my truck and love 'em; I'm used to the Paso's mirrors, I guess ...
1997 Monster 750
