Mirrors
- fasterdammit
Yes, I've had one of those pods apart and the mirrors are adjustable. Not easily, and it's not a great design (for more reasons than just adjustability) but they do pivot around in there.
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
- Finnpaso
ALL original mirrors are adjustable !!! But if havent move them for many years, they get stucked. I have fixed them many times, so i know.... Crashed my Pasos 3 times
- redpaso
- Location: Land of OZ (traylia that is) Troy Bayliss Country
So the Paso mirrors actually ARE adjustable?????????????
Well bugger me!
I have looked long & hard at mine & summised that they were just glued straight to the pod itself. I have even prodded & poked at them just to make sure. My old K100RS had the similiar Pod set up with indicators & mirrors in the one unit but they were easily moveable & there was room about the recessed mirror.
I have not removed the pods to check from behind but there does not seem to be any room about the recessed Paso mirror for it to move. I had better try again & carefully (& nervously)push a bit harder.
It is not actually going to make much difference though is it?
Well bugger me!
Redpaso
- Finnpaso
As I told, all MY 750 Paso:s and 907IE:s ORIGILAL mirrors are adjustable! I am 110% sure about it. Remembering, that U have to take blinker lens and bulb holder, etc. first away, then You can see some screw there(what is very often rusted) and hold another hand in mirror side and turn that screw open. If U managed that, then U can take mirror away and then You see that adjusting system: There is metal/plastic ball joint, what is just that adjusting. Normally that ball joint is stucked, if havent move it for long time. But DONT take that ball joint open, cause that plastic have hardened, so that plastic gets broken very easily, what happened to me one time and i had to glue that ball joint ..... Better sparay some thin lubrication inside that ball joint and start to move mirror little by little..... Was this enough badly explained???
- fasterdammit
A friend of mine mounted a pair of those car 'blind-spot' mirrors on his bike (not a Paso). They're convex, so they offer a slightly distorted view - but of a whole lot more real estate. If you can get used to them, they'll let you see more than your knees. I have them on my truck and love 'em; I'm used to the Paso's mirrors, I guess ...
1997 Monster 750
1997 Monster 750
