Anyone ever replace the fuse block on a 907? Mine is falling apart. Literally crumbling. Whatever the material is, it was not made to withstand the test of time.
Does anyone have a good aftermarket replacement for that item? I did order one for marine application, but it is a little large. It may work, and is high quality, but I think I will look for one closer to the original size.
Fuse Block
Fuse Block
1992 907ie, (x2) Anthracite
Re: Fuse Block
Eastern beaver has some good ones
Re: Fuse Block
When mine fell apart I used a Narva 54420BL. I used insulated spade connectors and bent the terminals a bit for clearance.
Willo
Wannon Victoria Australia
Willo
- IMG_0859.jpeg (148.36 KiB) Viewed 11141 times
- IMG_0858.jpeg (151.13 KiB) Viewed 11141 times
Willo
91 907ie
95 748
91 907ie
95 748
