Valve shim diameter
yosemite
Valve shim diameter
Post by yosemite »
Hi ,planning on checking the valve clearances, looking around the web there appears to be 2 different diameter shims that ducati use on different models each size needing different tools to measure and remove shims, so can someone please tell me which size ,7 or 8mm diameter are used on the 906
Re: Valve shim diameter
8mm
yosemite
Post by yosemite »
paso750 wrote: Sat Dec 24, 2022 8:51 am8mm
Thanks will get tools ordered
