Hi ,planning on checking the valve clearances, looking around the web there appears to be 2 different diameter shims that ducati use on different models each size needing different tools to measure and remove shims, so can someone please tell me which size ,7 or 8mm diameter are used on the 906
Valve shim diameter
Re: Valve shim diameter
Also recommend MBP valve collets
https://www.fastbikegear.co.nz/index.ph ... ts_id=6243
