Hi.
I have recently seen that this piece of the oil circuit does not fit in all Paso 750. In which versions were they mounted and what was their purpose?
Oil line...
Re: Oil line...
The answer is none. The same seller has a few other parts that are supposed to be Paso parts but aren't.
Sateme
- year: 1989
Re: Oil line...
But I have seen this engine with this part, like the one in the image.
It comes out of the lower radiator oil tube and goes to the rear of the crankcase.
Re: Oil line...
I stand corrected. Good eye! I've never ever seen or heard about that. By the looks of it the line is 20-30cm long. What is there to connect it to?!
- csa.jpg (78.54 KiB) Viewed 19633 times
- asd.jpg (92.52 KiB) Viewed 19633 times
Sateme
- year: 1989
Re: Oil line...
It goes to the rear crankcase bolt, where the anti-rebound brake bar bracket goes (look at the red line, that's the way). In this case it will be drilled.
