Dear all
Unfortunately, my control unit seems to have stopped working. I found an original part online at ebay —at a crazy price of 700 USD.
https://motorradteilehannover.de/Ducati ... gKiW_D_BwE
Is there an alternative? I would assume that this part was not only used for this model. Perhaps it was also used in cars from that era (Fiat?). I would be very grateful for any information.
Thank you!
Best, Hans
Control unit does not work
Re: Control unit does not work
Hi there,
you could of course see if Rudy has one. Another option would be https://www.carmo.nl/index.php?main_pag ... anguage=de to check and repair yours. They also sell their updated version https://www.carmo.nl/index.php?main_pag ... ts_id=1738
assuming your issue is the fuel pump prime ground missing it is easily repaired. Any ecu repair house can do it or with some deep diving around here you can diy it
I replaced mine with an ignitech unit when the bike started to run on only one cylinder, advantage of this was it can be programmed, although never felt the need on the paso, just run it with the standard programme, also fitted one to a 06 bonneville, personally can recommend them for service value and reliability
https://www.ignitech.cz/en/
Dear all, thanks so much for the feedback. Best, Hans
- year: 1989
I have a good 906 control unit I will sell for $150 plus shipping. Located in the USA
Reed H
Reed H
