Hi, I´m looking for mirror glass right ,indicatorglass right,lower fork tube left ,oillevelglass........
my tel nr. is+31653751522
thanx ciao,Serge
need for parts
it would really help if everyone would at least add your location in the profile.
Oillevelglass is available from your Duc dealer, same as indicator lenses. Some are always offered on ebay in combination with a reflector.
http://forums.ducatipaso.org/viewtopic. ... pic&t=1048
- fasterdammit
In the meantime, you can always get your mirror back by visiting any automotive glass shop - they can cut you a mirror, and will probably use the other one to source the proper size. (It think it's a fraction shy of 4" diameter). That's what I did a couple years ago; I think they charged me $5 ... it might not be Ducati's mirror or have the 'objects in mirror sticker' but I can see behind me all the same!
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
- fasterdammit
That's correct. Does the stock mirror have a slightly convex profile to it? I think I detect a very slight difference between the two - I guess that would explain it!
It's not the proper or ideal replacement, no, but it was better than going without ...
1997 Monster 750
1997 Monster 750
My word, Faster, do you realize what you're saying? Installing a non-Ducati part? What has the world come to?
there are 2 kinds of people in motorcycling, those that have read Zen and the Art of Motorcycle Maintenance, and those that haven't...
You can have a piece cut away from a convex mirror. That is what I did. You have to use tape in the back and put the glue on the tape. Do not use the glue on the backing since it will hunt you latter. It is necessary to seal the edge of the glass by some kind of coating to keep the moister out which causes the rust spots.
Max
Max
- persempre907
...or you have to use the special silicon glue for the mirrors.Max wrote:You have to use tape in the back and put the glue on the tape. Do not use the glue on the backing since it will hunt you latter.
Max
