need for parts
sergionic
need for parts
Post by sergionic »
Hi, I´m looking for mirror glass right ,indicatorglass right,lower fork tube left ,oillevelglass........
my tel nr. is+31653751522
thanx ciao,Serge
it would really help if everyone would at least add your location in the profile.
Oillevelglass is available from your Duc dealer, same as indicator lenses. Some are always offered on ebay in combination with a reflector.
http://forums.ducatipaso.org/viewtopic. ... pic&t=1048
fasterdammit
Post by fasterdammit »
In the meantime, you can always get your mirror back by visiting any automotive glass shop - they can cut you a mirror, and will probably use the other one to source the proper size. (It think it's a fraction shy of 4" diameter). That's what I did a couple years ago; I think they charged me $5 ... it might not be Ducati's mirror or have the 'objects in mirror sticker' but I can see behind me all the same! ;)
1988 Paso 750 #753965
1997 Monster 750
you got flat mirror glass, no convex glass, did you ?
fasterdammit
That's correct. Does the stock mirror have a slightly convex profile to it? I think I detect a very slight difference between the two - I guess that would explain it!
It's not the proper or ideal replacement, no, but it was better than going without ...
1997 Monster 750
I`m not sure about that. I was only wondering for a longer time if there isn`t a convex mirror glass replacement from another bike that could fit.
delagem
year: 0
Post by delagem »
My word, Faster, do you realize what you're saying? Installing a non-Ducati part? What has the world come to?
there are 2 kinds of people in motorcycling, those that have read Zen and the Art of Motorcycle Maintenance, and those that haven't...
Max
Post by Max »
You can have a piece cut away from a convex mirror. That is what I did. You have to use tape in the back and put the glue on the tape. Do not use the glue on the backing since it will hunt you latter. It is necessary to seal the edge of the glass by some kind of coating to keep the moister out which causes the rust spots.
Max
persempre907
Post by persempre907 »
Max wrote:You have to use tape in the back and put the glue on the tape. Do not use the glue on the backing since it will hunt you latter.
Max
...or you have to use the special silicon glue for the mirrors.
lceriani
Post by lceriani »
I replaced my mirror glass with a convex one from an old wrecked 50cc scooter (minarelli 50). It's only 1mm less wide but it fits.
