New Paso owner
Fubar
New Paso owner
Post by Fubar »
:thumbup: Hey, Just wanted to drop a quick thank you note! Hats off to SKINS and jsclocum your posts on "wiring upgrad" and "Sync Dellorto" carbs were right on the money!!! I recently took a 1988 750 Paso in partial trade for my wife's 2003 Sportster as she thought it was too top heavy. She liked the Paso as it sits low and it's center of gravity is low also. Anyway I have never touched a Ducati before and the bike was running poorly so what to do....dive right it. I took it apart and found it has Dellorto PHF 36 carbs, the previous owner milled the clip on out to lower the forks but the main problem was the single to splitter throttle cable was crap. I ended up finding you web site did some reading and ordered a double cable throttle from http://www.bevelheaven.com and 27" throttle cables, engine gasket kit, brake rebuild kit. It took me two days to tear the bike down clean it up, install the cables ( had to remove 7/16" of cable sheating to get the right length) and do the wiring upgrade. Read SKINS post on syncing the carbs and settings. Paso fired up after a couple of tries. With the mixture screw set at 1.5 turns out per SKINS suggestion I got the Paso to idle steady but if you blipped the throttle hard from an idle it had a large flat spot but if you ran the ticks up to around 1400 then give it a twist it took off. Anyway I ran the front carb a little leaner at 1.25 turns in and the rear at 1.5, fixed it idles great and revs cleanly. The wiring suggestions were right on the money as well. Thanks again for taking the time to help us uneducated folks out. :thumbup:
fasterdammit
Post by fasterdammit »
Congrats on the new (old) bike and welcome to Pasownership! You definitely found a great resource for info this site. Post up some pics!
1988 Paso 750 #753965
1997 Monster 750
DesmoDog
Re: New Paso owner
Post by DesmoDog »
Fubar wrote:... With the mixture screw set at 1.5 turns out per SKINS suggestion I got the Paso to idle steady but if you blipped the throttle hard from an idle it had a large flat spot but if you ran the ticks up to around 1400 then give it a twist it took off. Anyway I ran the front carb a little leaner at 1.25 turns in and the rear at 1.5, fixed it idles great and revs cleanly.
You probably already know this, but those carbs have accelerator pumps in them so when you open them up they squirt fuel. There is an adjustment on how much fuel they dump, but it sounds like you have it worked out already?
-Craig
Fubar
Post by Fubar »
:roll: Ya I also forgot to thank whom ever found and posted the links to Dellorto's website. I had a complete break down of how their carb functions and explained how the carb works at different rpm ranges. SO thanks again. But to answer DesmoDog yes I got it figured out..prob like 95% but I was expecting a high compression twin to have monster bottom end power it is decent but not a monster. I have never ridden a Ducati before and the only thing I have to gauge it against is my 2000 Dyna Super Sport which is a 1450cc twin so I might be expecting a little to much from the Ducati although my Harley only ticks to 6500 so its a trade off. It is decent but I think the carb is still off just a touch so I will let my wife ride it for a while then give it a really good going over. I will get some pics posted today soon as I charge the camera battery.
Fubar
Post by Fubar »
Heres a couple of pics of my wife's Paso
Finnpaso
year: 0
Post by Finnpaso »
Cute Paso!!! But, have U any pics from U wife???? :evil:
907IE -91 red/metal grey
907IE -91 red
ducapaso
Post by ducapaso »
What's hiding under the car cover?
pikey
Post by pikey »
beautiful paso, not such a good trade financially, but the paso is a much better machine in my opinion.
-pikey
jcslocum
Post by jcslocum »
The 750 pulls pretty good for it's size and age. It will never have the deep torquey feeling of a 1400cc motor. The Paso is a great combination of power and handling but it is 20 years old! If you want elbow pulling acceleration, go to a local dealer and try out a Multi 1000 or Monster 1000. The new dual spark motor pulls like a tractor and will pull like that all they way to the red line.
