You probably already know this, but those carbs have accelerator pumps in them so when you open them up they squirt fuel. There is an adjustment on how much fuel they dump, but it sounds like you have it worked out already?Fubar wrote:... With the mixture screw set at 1.5 turns out per SKINS suggestion I got the Paso to idle steady but if you blipped the throttle hard from an idle it had a large flat spot but if you ran the ticks up to around 1400 then give it a twist it took off. Anyway I ran the front carb a little leaner at 1.25 turns in and the rear at 1.5, fixed it idles great and revs cleanly.
