Gas Filler Gasket
Gas Filler Gasket
I have a 1992 907ie, and am in need of a rubber gas filler gasket. Seems to be a discontinued part at the local Ducati dealer. Anyone have a resource?
I've had good luck with these guys in Illinois:
Motor Cycle Center
518 W. St. Charles Road
Villa Park, IL 60181
630-782-2010
They seem to have a lot of Ducati parts and may have what you need. I'm pretty sure the filler cap was used on other bikes than the 907, so you might want to take the gasket off and measure the OD/ID. If you can't find one , you can get blank gasket material and make one yourself. I have a '92 and live in Tustin, so if you need any other help you can email me directly. jim@youngwikle.com
Jim
Motor Cycle Center
630-782-2010
Jim
It'so.pencilbeam wrote:I'm pretty sure the filler cap was used on other bikes than the 907, so you might want to take the gasket off and measure the OD/ID.
For sure, the same filler cap has been used on the 851/888 and also on the early belt driven SS.
Good Luck
RATS!MJP wrote:Thanks for the suggestions. I tried the Austrailia resource, but no luck. I'll try the one in Illinois tomorrow.
Gowanloch blew me away with the stuff they had on hand, guess I was lucky to score a gas cap gasket when I did.
Oh well, please do let us know if you have any luck and/or find another source for parts.
Regards,
Randy
'02 BMW RT
'06 BMW K1200S
Randy
'02 BMW RT
'06 BMW K1200S
