Is the regulator dying?
Today my battery bulb seems go crazy: sometimes it stayed on until 3000 RPM, sometimes until 2000 RPM, sometimes it stayed off when the engine idles.
Is the regulator dying :sad: ?
ducatipete
Post by ducatipete »
Try checking the main 30amp fuse on + battery terminal, if you have one. Mine is a 906, mine started to overheat, replaced it red light stayed off... :lick:
Measure over battery + & - w voltmeter :
At idle should be about 12,5 V, over 3000 RPM 13,5-14,5 V.
Over 15 V 3-4000 RPM, faulty regulator.
mrinflux
Re: Is the regulator dying?
Post by mrinflux »
persempre907 wrote:Today my battery bulb seems go crazy: sometimes it stayed on until 3000 RPM, sometimes until 2000 RPM, sometimes it stayed off when the engine idles. Is the regulator dying?
Yes
'91 907ie (Red)
'93 907ie (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
