i need a ECU - Urgent for my 907 IE
duki
Post by duki »
I Need this part :dunno: http://lh6.ggpht.com/92pasoie/Rmyr40C-1 ... imgmax=512
Im looking for an Electronic control unit (ECU , BRAIN Whatever you want to call it) is the silver square box under the seat
anybody know if this ecu can be replace it/ match it with other brands or other type of motorcycle ?
any generic brand available , can this unit is repairable ? :phone:
please contact me to lumir@bellsouth.net
Regards
Laddie907
Re: i need a ECU - Urgent for my 907 IE
Post by Laddie907 »
the 907ie standard is a Weber-marelli P7 ECU
they are supposed to be bullet-proof; are you sure it's dead?
I'd get it fully checked out before you get another...
there are after-market ones available but pretty expensive.
if you were happy with the standard unit it should be easy to get another P7.
cagiva elefant 900ie
motoguzzi
they are a common in cars from 1990 - 1995:
Peugeot
Citroen
Ford Cosworth
and I believe some eastern block cars too..
you will need the Ducati Eprom chip from the old ECU.
...and many FIAT group cars.
What's happened to your ECU?
duki
Post by duki »
Laddie907 wrote:the 907ie standard is a Weber-marelli P7 ECU
motoguzzi
Peugeot
Citroen
Ford Cosworth
hey guys , this is what happen :
:arrow: is not passing the information to the fuel injectors , i was riding my bike and suddenly stall , i checked everything :coils , starter motor , plugs ,air intake ,electronic ignition,remote switch,voltage regulator , fuel pump , gas tank ,relay fuse ,potentiometer,pressure regulator ,injection wiring,pressure detector ,
Laddie907
Post by Laddie907 »
check the kill switch?
seems odd it would just stop...
I have heard of the ECU being damaged by a battery cell collapse & failure.
If supply voltage drops below 11 volts things get pretty sick.
if there is no power to the injectors it would strongly indicate the ECU was part of the problem.
before i plugged in a new one I'd want to know the cause of the failure...like if there is some other electrical fault that caused the ECU to fail.
I'd be inclined to have an EFI technician go over the ECU.
When you turn ignition on, do the fuelpump prime for 4-5 seconds?
duki
Post by duki »
Tamburinifan wrote:When you turn ignition on, do the fuelpump prime for 4-5 seconds?
yes , prime for 4-5 seconds /
duki
Post by duki »
Laddie907 wrote:check the kill switch?
:arrow: :idea: ok let me consider this .
regards
duki
duki
Post by duki »
Tamburinifan wrote:http://www.ducati851and888.com/showthre ... hlight=ecu
Maybe your problem?
thanks for your information but i can't download the picture ,i tried to register in this site but im not receiving my
log in information .
regards
duki
851/888forum pic:
Have you checked the pick up on the flywheel?
It broken on my old 906.
Rasser
Post by Rasser »
Hi,
On a trip to the Dutch TT a few years ago my 907 wouldn't start after a tank stop. I figured it out to be one of the relays. I got another type and continued. Figured out later that these had terminals which did not match completely and would drain the battery if not removed when stopped. Did that for a while and then took the time to open the old relays.
Very obvious when first opened was that the plastic had melted around one contact, just a bit from the heat of a poor contact, allowing contactpoints not to touch when the relay switched. I cut a bit of plastic from the sides of the contact, filed the points and it all worked again.
It may be the same thing for you.
Regs
Per
englishstiv
Post by englishstiv »
Caught up on this today I have an exact same problem with mine however after removing the tank and stripping out the pump and checking all the relays etc I have found that the problem was in the female connector that attaches to the housing under the tank, within the plastic shroud of the connector the wires were corroded. I stripped back to new and replaced the connectors and the pump now seems perfectly happy.
When it first occured if I shook the bike from left to right (leaning into corners fashion) the pump would fire up and then stop - probably as the wire was swinging under the tank.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
vtduc
Post by vtduc »
did you ever get your ecu ? b.t.w. that is my picture your using to show the desired item
