You loosen the reservoir, move the idle lever so it slips out of its seat
and then you`ll see the screws f the idle assy to be removed from clutch reservoir.
A bit tricky and not so few words.
(Also, reservoir had to be worked over abit to make the repair kit work. )
The idle lever cover loosens when positioned halfways over piston/
dust cover in reservoir.
And of course reassembles in very same position, dust cover/piston must be compressed a bit.
The wire mount hole towards el controls is the one to use, why there is another, who knows...
All easier if wire loosened at TB`s.
So now, .
Did You get repair kit ??? From where??? What price?
Dont too much! I have done it sometimes and suffered about 4 days from it... Cant eat anything for 2 first days... then little by little same time quessing, does all come out very fastly, or after some minutes...
