I have my ignition lock broken, (canot lock stering) went to my dealer and this part is no more available...
anyone knows if the one off the new ignitions lock will fit the paso?
Ignition lock
Re: Ignition lock
did you try to take it apart ?
Re: Ignition lock
No, but i have seen pic in the net that seems to have the new ignition lock, just not know from what ducati bike:paso750 wrote:did you try to take it apart ?
see pic
http://www.westmoreland-moto-guzzi.com/ ... %20669.jpg
Re: Ignition lock
Ignition lock again... my bike stop working, no lights no neutral light no start, take the ignition lock off to see if the problem was here, and it was, melted the inside of the plastic casing!!!
So i need a ignition lock to run my bike again, anyone knows what type ducati "bike" is the one in the foto?
I have read that the Gilera SP01 has the same ignition lock, anyone can confirm this???
Re: Ignition lock
Are you really sure is the lock? Have you tried to by pass it?
I guess that lock is from a 916.
Re: Ignition lock
yes if i bypass it it will work fine....
Re: Ignition lock
Take it apart and bring it at the Ducati dealer...
Besides, check on ebay: sometimes you can find something.
http://cgi.ebay.com/ebaymotors/DUCATE-P ... ccessories
Ask him if there is the lock too. By the pics, it seems included.
- micklm
Re: Ignition lock
Hi,
It also looks alot like the ignintion lock/barrel on my 1994 supersport from the photo you have........probably the same as the one on the 916 as well?
I can get a photo and probably some dimension and wiring details on the supersport ignition lock/barrel on the weekend if it's useful (sadly I no longer have access to a 916!)
cheers,
Mick
cheers,
Mick
- JWilliam
Re: Ignition lock
Please see this link for the repair of an ignition barrel - if its not too far gone. Thanks to a thread from the 907 forum.
http://www.box.net/shared/4evp1px5be
Re: Ignition lock
Thanks to Gerhard (paso750), I`d sayJWilliam wrote:Thanks to a thread from the 907 forum.
