New Paso owner
New Paso owner
Great board you all have here. It helped me pull the trigger on buying my 1987 750 limited today. I promise to do a search before asking any questions
1986 Guzzi BOTT Racer
- randtcastell
Re: New Paso owner
Congratuations! Discerning choice you've made. Pictures, provenance please.
Best, Randy.
Best, Randy.
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
Re: New Paso owner
Re: New Paso owner
Re: New Paso owner
As for provenance, I'll have to do some detective work. The guy I bought it from got it 10 years ago from a ducati collector who was getting divorced. She ws built in june of 1987, and might have come from california (pro italia keychain, and front and rear suspension from lindemann engineering which looks like it was done when the bike was pretty new.) The vin is ZDM1DA3N6JB 753581. what's up with the gold rocker covers ? Is that correct?
- randtcastell
Re: New Paso owner
She-it that's a lovely bike bro. Beautiful. I believe the 87 Pasos had black rocker covers. '88 on got gold rocker covers denoting an improvement/revision to the valve adjustment. Others on the forum can more accurately describe this revision. I have an '87, so I'm no expert so I'll let them explain. Thanks for the pictures and info on the bike!
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
Re: New Paso owner
Thanks ! She's a little more rough than the pictures suggest, but considering there are 30,000 miles on the clock, pretty nice. She's been sitting in a garage for the last 8 years, so there's gonna be some work to get here roadworthy.
- 21783mike
Re: New Paso owner
I have to dig out Fallon's book to double check but the Rocker covers went on the Limited only in 87 and the rest in 88? Some change was made in the top end I think.... dang I knew all this by heart at one time, it sucks getting old
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
- 21783mike
Re: New Paso owner
March of 88 the rocker set up changed.... removable clip and shorter rocker so the pin no longer needed removed when doing valves those with that system got gold anodized rocker covers. I do recall reading somewhere that some dealerships retrofitted this system to older style bikes, whether what I read was true or if it was possible actually I do not know.
According to the chart I'm looking at, everything above 752608 was built as an 88. So Gold anodized rocker covers should be right.....
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
- streetsurfer
Re: New Paso owner
Congratulations. I like your exhaust.
Bike looks very clean.
You have an earlier serial than I do. 7540** here.
Is that a seam in the seat covering at the front?
Re: New Paso owner
that's a Corbin saddle. I've got the original one too. The exhaust is a set of staintune pipes on the stock headpipes.
Re: New Paso owner
An Alfa and a Paso, glutton for punishment.
Re: New Paso owner
and a Hayabusa
- Desmo_Demon
Re: New Paso owner
My 1987 has black valve covers and the older version of the opening rocker design, which makes valve adjustments a real PITFA. I've thought about finding a set of newer rockers with clips the next time I have to adjust the valves....and then paint the valve covers red to confuse people.21783mike wrote:March of 88 the rocker set up changed.... removable clip and shorter rocker so the pin no longer needed removed when doing valves those with that system got gold anodized rocker covers. I do recall reading somewhere that some dealerships retrofitted this system to older style bikes, whether what I read was true or if it was possible actually I do not know.
