I used these ones off ebay
http://www.ebay.co.uk/itm/110722266136? ... 3168wt_964
Cheap and cheerful although not very well put together but they did the job.
I'd probably have been better using these which would fit in the original bulb holders.
http://www.ebay.co.uk/itm/T5-286-White- ... 1453wt_964
Its a bit of a task changing them, I found it easiest to remove the instrument panel. You also have to make sure you fit them the right way round as LEDs are directional and don't light up if you get the polarity wrong.
