going to start putting it together question
bobst2
Post by bobst2 »
at my electric,s plate near the headlite there are two ground wires 1 goes to the regulator but the other i broken off just hanging there any ideas where it goes
Re: going to start putting it together question
Do you have 2 wires from alternator cover to regulator?
bobst2
Post by bobst2 »
yes. two wire stator
i think i figured it out the electric,s board is on rubber isolators so the second one must go two the frame
bobst2
Post by bobst2 »
well fired it up with the 2 into 1 conti alloy system and it sounds great. had to do a little hammer mods to the front pipes to get propper clearence. started testing stuff found i had no chargeing system but was only a bad connection now that system is working now i am going on to the brakeing system going to need hoses and a proper flush also the micro switch is shot. hopefuly the last of the body panels & stuff arrive soon.i am starting to get anxious to take it for a ride
