blue wire out of left side handle bar switch
katescottageiom
I can not identify this wire, was connected to frame tube just down from the re/rectifier mount. Is this a ground wire? It is blue not black, and connects into the left side handle bar switch. Diagram does not show it or I just can not see well enough at 68!
- Derek
- year: 1994
Re: blue wire out of left side handle bar switch
It's the ground wire for the horn button.
Derek, that would be the grey wire.
The diagram shows:
https://app.box.com/shared/3elasen7q7
There`s a blue/black going to the flasher relay and a blue which seems to be low beam.
The diagram shows:
And if someone has fitted a two pole relay to the headlight that blue wire might be redundant
- Derek
- year: 1994
I beg to differ. The grey wire is from the horn to the horn push button and is shown on the diagram as that. The horn button provides a connection to ground and is shown as a ground point on the diagram. In reality there is a blue wire from the switch, separate from the multiconnector which is connected to the frame to provide the ground for the horn button.paso750 wrote:Derek, that would be the grey wire.
The diagram shows:
I know this because I just repaired the horn on a friends 900SS last week. The horn didn't work because the blue wire had broken off from it's terminal, in the 900SS's case bolted to the bottom yoke. The 900SS uses the same LH switch as the 907.
katescottageiom
Thank you all, now I can push forward with confidence to the next issue, locating the correct 7mm in tank injection line.
nickta
Have a read of the topic http://forums.ducatipaso.org/viewtopic.php?t=6277
All you never needed to know about fuel line!
Cheers.
Nick.
Cheers.
Nick.
