Mikuni conversion?
commotoed
Mikuni conversion?
Post by commotoed »
I have gotten my 750 sport out to finish my upgrades, anyone have any specifics on the oe mikuni conversion ( jetting, fuel pressure restriction...)
90' 750 Sport
97 Gsf1200 aka Ziptie
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
Re: Mikuni conversion?
Have a look at the P750 FAQs.
commotoed
Post by commotoed »
does the mikuni conversion need the fuel pressure regulator?
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
If you had a P750 I'd say, absolutely but I don't know if the specs of the 750S in-tank fuel pump are the same as the one used on the Paso. I'd try w/o but do keep the return line to the tank. In case you run into problems try to remove the jet that sits in the Y-piece. This will increase the amount of fuel returning to the tank. If you still have problems you can add a fuel pressure regulator.
commotoed
Post by commotoed »
Thanks, will do...
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
commotoed
Post by commotoed »
https://www.youtube.com/watch?v=dliSUJACpw8
Awake after 8 years in storage, Mikuni conversion, Verlicci 2 into 1, rear shock rebuilt, forks serviced, new Michelins....
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
88Sport
Post by 88Sport »
Not bad from 8th Feb to Mar 15th ;)
